I am new....I have the oddcast V3 and have everything hooked up. It won't connect though. It trys over and over again. My internet connection is good so I know it isn't a network problem. Any advice?
Make sure the info provided by RR is correct in oddcast. You might also have to restart your computer. I had to do this for it to work properly for me. However, I'm now using ScannerCast which is alot easier to use then oddcast. Hope this helps!
