10-Codes
mfbenderjr
Portage County, WI
I have recently moved to WI from the east coast where I was a dispatcher and having some trouble locating 10-codes for the state. Interested in WSP, Marathon, Portage counties and there respective municipal agencies. Is there a uniform set of codes or do agencies use there own systems? Also, do agencies in the area typically use military or civi phonetic alphabet...Thank you.
canav844
I had the same thing happen when I moved to WI after dispatching. Seems to be mostly APCO ten codes, with a few odd balls (10-100 = Status). I still get a few every once in a while that I have to strain to put together. I'm not sure if it's an attempt at plain language, but there's also not much brevity out of the Accuracy, Brevity, Clarity mantra, so often times if I give it a discerning ear I can get enough context to figure things out.
takyrob
Winchester, VA
you can send me a msg and i can send you a nice little booklett that i made with 10 codes for Waukesha, and MKE
MarcusDude
Appleton, Wisconsin
Wisconsin uses the APCO (civil) phonetic alphabet (ADAM, BOY CHARLES, ect), as apposed to the military phonetic (ALPHA, BRAVO, CHARLIE, ect).
mfbenderjr
Portage County, WI
Thanks for the 10-code list! Some interesting ones in there...such as livestock on highway? Don't see that back east, suppose it comes with the territory! I also notice that a lot of agencies tend to explain EVERYTHING over the radio and don’t always use a lot of codes...back east we would use a lot of 10-21 (Calls to HQ or personnel) simply to reduce radio traffic due to the higher volume (in the big cities - was in New Jersey in the New York Metro Area) If you listen to the live feeds I encourage you to listen to Northern New Jersey Feeds just to hear the comm differences between the regions (I find it interesting at least...maybe I'm just odd)
Also looks like I may soon need to update my equipment, antennas at least (due to the differences in terrain, and most of my previous monitoring was with UHF and massive trunk tracking systems) Any suggestions?
I will for now just have to listen more closely then I am used to...and any more information would be helpful!! Thanks Again.
Operator: 290
PS: Anyone know of agencies in the Portage, Marathon, Wood, and Waupaca county area's hiring for comm officers/dispatchers? I check the job boards but maybe someone has some insider info? Working in sales right now to pay the bills but want to get back into the game!
sfd119
Some bigger cities do this as well, but others don't as you have found out.
Most of Wisconsin is VHF, although some pockets of 800MHZ and UHF do exsist. Also, the new statewide system (called WISCOM) uses VHF.
