Hey all - I'm trying to make an adapter to connect a headset to the 10-pin front connector. I've found some information regarding this but not sure it's accurate. My question is surrounding the accessory detection interface pins (1&10).
See attached images - I believe I need to supply 3.3V to pin 1 and ground to pin 10. However, i'm not sure where to get this voltage source from. The pinout would indicate that pin 6 would give me 5V, but it does not. It seems to also be looking for the accessory config. The D+ source (pin 8) gives me 2.9V which i'm not sure is enough - I've tried this and it doesn't work, audio still only comes through the mobile unit speaker.
Has anyone wired a headset (with Mic, PTT, and headset speakers) to the front 10-pin connector?
