2 Data connections
INLANDSMOG
Abingdon, VA
Hello all,
I have a 996 that is connected to 1 computer 24/7 streaming Butel Easystream and a WMP stream which all works great. My question is there a way to use the rear port to connect to another computer to run ARC996 for logging and/or programming without having to stop the Easystream feed ?
Thanks,
Craig
www.scanOC.com
Al42
Long Island, NY, USA
You can connect the rear port (use a null modem and adjust the speed), but whether the scanner will give you logging output on both ports at the same time (you want the same data on the back port that you're streaming from the front port) is something you'll have to experiment with or ask Paul.
Butelsoftware
Dayton Hamvention
INLANDSMOG said:
Hello all,
This is not possible, you can not control and program the scanner using both ports at the same time. Even if it was possible the scanner goes into a program mode when programming data so that would stop the Eazystream display feed.
Gommert
www.butelsoftware.com
