The Hustler CG-144 is made for ball mount use and its tunable. Just make sure the center conductor of the coax going to the ball mount is as short as possible. It's also a very rugged antenna and I've known people that have run them for 10+ years with no problems. One guy had his on the roof of a VW van and it was always hitting something but never seemed to break.
There is another "secret" antenna out there that might be better than the Hustler CG-144 and this one probably has more gain than any 2m mobile antenna out there. Its 8ft tall and uses a PL-259 mount but I have a PL to NMO adapter on one and it works fantastic.
This antenna has a base coil and fold over feature right above the coil and its also fairly broad band covering more than the 2m band with a great match. Best thing is its only $30 including shipping. The person selling them doesn't really know what they are and after I order another one I'll post a link to them, since there is a very limited supply.
prcguy
I can make the pl-259 work. At least it has more threads than my NMO mount. More threads per inch is much stronger. I can understand why people tell me to use the NMO for it's universal with a lot of different antennas.
I don't like the folding part of the antenna. If I have to I may remake the antenna with some good materials and it not fold. I would have to see what it looks like first before I make that decision.
There is a reason NMO and not SO-239 is universal in the LMR world for antenna mounts.
This sounds great. I want to purchase one or maybe two of them. Do you have the link or can you PM me something since they have a limited supply and all the ebay'ers find them and run the prices up?
I can make the pl-259 work. I can use a SO-32 chassis mount with a larger plate at the bottom of it for support. At least it has more threads than my NMO mount. More threads per inch is much stronger. I can understand why people tell me to use the NMO for it's universal with a lot of different antennas.
I don't like the folding part of the antenna you are talking about. If I have to I may remake the antenna with some good materials and it not fold. I would have to see what it looks like first before I make that decision. Any extra connectors or weak links I want to avoid. I want to be able to take it off my truck and beat the bark off 10 trees then put it back on and talk. Just like the fishing pole the ugly stick. LOL
Yea, I do not like fold over antennas either.
Sent from my iPad using Tapatalk
The threaded piece in the photo of the Larsen antenna is not the NMO mount. Actually, you have screwed the antenna whip off of the mounting base. The NMO mount is below the base.This is my Larsen Mount...
If you grasp the large plastic mounting base on your Larsen antenna with your hand and apply some torque in the correct direction (righty-tighty, lefty-loosey), it should screw off of the NMO mount. An NMO mount has a 1-1/4 inch thread, I believe. Bigger than 3/8-24. Bigger than a PL-259/SO-239 mount.
The threads you show at the top of the NMO base are 5/16-18, I believe. That threaded connection works just fine for Larsen whips (and Laird/Antenex whips and Maxrad/PCTel whips) because they are flexible and don't present a high bending moment to the threaded connection. Mounts with 3/8-24 are useful for long whips made of stiffer wire with higher bending moments. A Larsen NMO150 antenna is a 5/8 wave antenna so it's about 48 inches long at 146 MHz. That whip is made from wire that's no more than 0.100 inches in diameter and it tapers down to smaller than that. A standard NMO mount will work just fine. OTOH, a 102 inch CB whip is not only much longer, but made from larger diameter wire so it presents a lot bending moment on the mount. A 3/8-24 mount make sense for this kind of antenna.
In the middle of weed eating the postman stops me and gives me my package and it does not look like the antenna as described nor in the pic. This antenna that arrived is not 97 inches, it don't have the pl259 end but only a threaded stud, it has some sort of tuners to tunes swr kind of like a antron 99 does, it does not fold, and it is cheaper made than I have ever seen in my life. I contacted the seller not going to give a bad review but, however return the items and get my money back. Now the search continues in finding that tall antenna with high gain to sit on top of roof of my truck. If anyone has ordered any of these in the link to ebay did yours look like this? What I received was a 48'' tunable CB antenna.
That's not the right antenna! The antenna in question was originally advertised as an NMO and I ordered one knowing it was PL-259 and when I questioned it later the seller refunded some of my $$. I'm sure they will take care of you and get the right antenna shipped.
prcguy
Brett, i th truck lik th one that shows on your name. If its taller, from the ground up, than 6 ft, 72", then you add a 97" antenna, Thats 14.08 feet tall. Most over passes on thhe Interstates are less than 14 ft clearance. You are going to hit one and snap the antenna. I think 48 to 60 inches is what you want to stay with. The times I loaned out my tall Mahdol antennas, they came back broken each time. Mahdol is part of Diamond Antyennas now and I think the tall co-linear design has been discountined.
