2 Questions
VA3SOM
Ontario, Canada
1: A Burlington Transit driver told me that they also have a Channel 5 and Channel 6, anybody know what talkgroups those are?. I assume the drivers prob do not know.
2: anybody know the Security freq for Burlington Mall?
EJB
20 + year membership
Downtown Hamilton
1) I generally block out their boring comms, they are about as exciting as listening to paint dry but I hear them on 02-101 thru 02-103.
2) I might have to venture to a mall tomorrow. I doubt I will take my scanner (hard to conceal it waering shorts). The next time I go there I will have a look out for them and report if I remember (I dont go there often enough)
EJB
Downtown Hamilton
Where in Burlington are you and what scanner do you use?
Aldershot and 396T with a Pro2045 running T88 here
There are a few of us here; always good to swap info.
Eric
VA3SOM
Ontario, Canada
Eric
i live near Upper Middle and Guelph, using a 396Xt, PRO-164 and a 996xt. i would also be happy to swap info at any time.
VA3JWO
Madoc, Ontario
if your looking for a mall frequency, get real close to the mall, and turn on the close call if you have a uniden scanner. it worked for me, but that was at a different mall
EJB
Downtown Hamilton
PM me if you have any questions or files or ask away.
The 396 xt follows RIDS IIRC?
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Considering the first four talkgroups for Burlington Transit are in AFS or DEC:
(02-101 or 337) Burlington Transit 1
(02-102 or 338) Burlington Transit 2
(02-103 or 339) Burlington Transit 3
(02-104 or 340) Burlington Transit 4
would it be safe to assume channel 5 would be.. 02-105 or 341, and channel 6 .. 02-106 or 342 ?
mciupa
Canadian DB Admin
Moderator
I'm here a lot
In TAFL, it shows
Code:
Search Results Tx Frequency (MHz) Rx Frequency (MHz) Station Location Licensee Name
451.187500 456.187500 BURLINGTON, ON IVANHOE CAMBRIDGE II INC. BURLINGTON MALL
454.200000 454.200000 BURLINGTON, ONTARIO AND AREA IVANHOE CAMBRIDGE II INC. BURLINGTON MALL
456.187500 451.187500 BURLINGTON, ON IVANHOE CAMBRIDGE II INC. BURLINGTON MALL
you can bet those will have PL or DPL tones as well.
VA3SOM
Ontario, Canada
In TAFL, it shows
Code:
thanks, ill check those out when i get home.
