I just purchased a used 2004 Civic Sedan. I went out tonight to mount the trunk lip antenna mounts i've used, and noticed that they don't work that well. If I mount them in the center, by the brakelight, the lip of the trunk is beveled. If they are mounted on the size, there is a seam on the underside of the trunk that keeps the screws from tightening down properly (the screws dig into the side of the seam, and slide toward the mount.)
I thought about an L bracket, but there may not be enough clearance between the screws and the sizes of the quarter panel. I really don't want to drill 3/4 inch holes for an NMO mount yet.
Does anyone know of a trunk lip bracket that has the screw holes positioned further from the edge, or another type of mount that I can use?
Thanks,
Warren
Thanks,
Warren
