2008 Trailblazer
gallagher073
Connecticut
Need to mount an VHF antenna on a 2008 Trailblazer. Wish I could drill a hole in the roof and NMO mount but the car is not mine. Need to do a fender or other removalable bracket. Standard L bracket looks too tight. Wondering if anybody else has done this.
Please advise
tlfd40
Upstate NY
2007
Please advise
i had a 2007, i had a magnet mount and then i also had the qtr panel mount. A communication company installed both, seemed like a typical L bracket
N8GXZ
17 miles south of Lake Erie
I have an 07 Trailblazer and use a mag mount in the center of the roof use a black wire tie and tie the coax to the roof rack and run the wire in the rear door . The last time I drilled any holes in a vehicle was a 1972 Plymouth fury 3, I put a 102 inch whip on the rear side. Been using mag mounts ever since . Works good for me.
N5TWB
Sand Springs OK
Look at the Comet line of adjustable brackets that you could use on the back door/hatch. At least that would get the antenna up high.
ambdrvr
08 Trailblazer
Gallagher073,
Is the vehicle a company or lease vehicle or is it just your spouse's vehicle? The reason I ask is there is no depreciation value for installing a permanent antenna on the roof towards the retail value. Also if your willing to drill 3 holes for a "removable" mount I would think it would be better to drill 1 hole for a better permanent mount. Just my 2 cents worth but I thought I would throw that in. I did an install on an '08 Trailblazer and I put all 3 antennas on the roof as well as the lightbar and it worked perfectly. If/when you are ready to get rid of the vehicle you can just pull the cable kit out and plug the hole with a plug, out of site out of mind, nobody will even know you had an antenna installed. Hope this helps.
Ambdrvr
gallagher073
Connecticut
I'm not afraid to drill holes in my roof, trust me. I've got NMO mounts in my truck.
The trailblazer belongs to friend of mine who wants a CDM-1250 installed. On his old car I just used a standard L bracket but the design of the hood looks like it may not be possible. I tried to convince him to let me drill a hole in his roof but he keeps saying no.....WIMP!!!! lol
I'm going to take another look tonight when I see him and maybe I'll find a good spot for the L Bracket or I'll convince him to let me drill a hole in his roof.
N467RX
Panama DB Admin
Prescott, AZ
Hey colby, any chance you could post a picture of the bracket and location of it? I'm considering on doing one on the hood for an NMO CB antenna.
I currently have an antenna mounted dead center on the roof with a magmount, cable ziptied to the cross rail and then it goes into the cab at the rear right door. I also have one on the back, with the cable going in at the tailgate.
I designed a mounting bracket to mount an L bracket to the roof rack WITHOUT drilling it, if you want pictures I can take some. I'm currently working to improve it, grounding isn't the best, but people who have mounted antennas in weird locations sometimes run a grounding wire to a chassis ground location.
I designed
n3qam
PA
You can mount it on the left front just below the hood hinge. Just use a screw with a low profile or flush head.
This is not the best pic of how I USED to have it. I have since just punched through the roof .
