2015 Explorer Install
robertpearsall
Edison, NJ
After doing 100's of installs on many vehicles, I can't do my own. I am trying to install an XTS 2500 into my 2015 Ford Explorer and I can't get through the firewall. Is it possible to pull battery power from key switch battery? If not does anyone know where to get battery power from?
Are you installing an XTS-2500 or an XTL-2500?
If it's an XTS and you just need to connect a charger or battery eliminator, use the cigarette lighter plug, or find another easy source of 12 volts inside. Sometimes you can find wiring bundled up for accessories you don't have on your vehicle. Pop in a fuse and reuse the circuit.
If it's an XTL-2500, then you can often follow existing wiring. Start from the engine bay side and look for a large wiring harness running through the firewall near the brake master cylinder. On the last bunch of Ford and Chevy's I've installed in, there's a nipple on there than can be cut off and it's a pass through for after market wiring. I've run as large as one #6 conductor through those, so the power cord for the XTL should fit just fine.
robertpearsall
Edison, NJ
Sorry guys it is a XTL2500 looks like I am going trough floor thanks for the help once It is complete will upload photos.
Don't go through the floor. There's no reason to do that, and running your cable under the vehicle isn't the best option.
Look for those large grommets where the existing wiring harnesses run through the firewall. There will be one near the master cylinder and probably one on the passenger side, also. Look for the little raised nub on it. Cut that off and you'll be able to feed your wiring through.
Wauk620
KD9PQM
Wisconsin
You can also use one of the unused hot connectors in the fuse block under the dash. Just get the proper size fused tap with a pigtale and run your hot lead off of it. Run your ground to a metal section of the firewall. I’ve done this with my GMRS, XPS and APX mobiles without any problems. Check the unused fuseblock connectors for rating at 15 or 20 amps, so be sure to pick the one rated higher than you need.
