2022 Camry SE
sgtmatt
Platteville Wi
Hi, I just bought an XTL 2500 that I'm wanting to get installed in my car. Its not a hibrid car so I'm not sure if it has the extra battery in the trunk. A local ham that helps me with my installs has a general idea on what to do but when we opened the fuse box he wasn't sure where to connect the positive side. If someone could give a few pointers that I could pass on that would be great. We also had some issues running the leads through the fire wall as well.
kb4mdz
Cary, NC
An XTL2500 really deserves to be fed power from as close to the battery as possible, so going thru the firewall is pretty much mandatory.
Ignition sense can come from a fusebox, but main lead is much heftier than you should ask a fusebox to deal with.
Maybe check in some Toyota forums; I have a CR-V and there are occasional discussions about installing ham radios in the Honda CR-V forum.
03msc
RF is RF
The Natural State
As kd4mdz said, run to the battery or the terminal bar beside the battery, depending on how your car is setup (some newer vehicles have a positive bus bar next to the battery where other things connect). Don't try to tap it inside the car. If your ham friend thinks that's a good idea then he isn't as experienced as you might need.
