2025 IndyCar FREQUENCIES
glennhl
Mesa, AZ
I do not have permission to access your signature. Could you post your freq list and Bearcat files in the thread? Thank you so much.
glennhl
Mesa, AZ
Thank you so much. And when I try to click your signature, it won't allow me. But thanks for pointing that out because I can copy and paste the URL you have listed.
TheMann00
Let's get to the updates!
I've updated my page with IndyCar and now IndyNXT (based off of their spotter guide)
All files updated. CSVs don't have IndyNXT - but Bearcat file has EVERYTHING. Enjoy!
TheMann00
Here are the long-awaited Indy 500 updates!
7 additional drivers outside of the normal series are trying to get a spot in this years race.
  • Helio Castroneves – 06 – 460.3375(p) | 456.7625(b)
  • Kyle Larson – 17 – 456.1375(p) | 459.7750(b)
  • Ryan Hunter-Reay – 23 – 453.3750(p) | 458.3750(b)
  • Jack Harvey – 24 – 461.0125(p) | 466.0125(b)
  • Ed Carpenter – 33 – 467.7125(p) | 465.0375(b)
  • Takuma Sato – 75 – 460.4250(p) | 457.1750(b)
  • Marco Andretti – 98 – 464.1375(p) | 463.3500(b)
As always- I have full frequencies and config files for Bearcat, and CSV for Baofeng/Tidradio/Etc on my page: 2025 IndyCar Frequencies
TheMann00
Looks like the initial Spotter Guide that came out had 4 frequencies wrong.
I've updated my site (again) to reflect these changes, and the message above is now inaccurate about #17 Larson.
His updated frequencies are 460.4500(p) and 456.1375(b)
glennhl
Mesa, AZ
Mr. Mann, thank you for the current freqs list for the BC125 scanner. Great job. Saves me a lot of time. Red Bull coming your way. ;-)
TheMann00
Thanks all! I love getting this info out there!
Speak of... for FAST FRIDAY I have updated my files to v3- which now include local Indy area ham repeaters on Bearcat bank #9, and a smaller (but useful) selection of repeaters in the chirp file. Just a little something extra to listen to when there is downtime, bad weather, etc. I also put NOAA on both files too! 2025 IndyCar Frequencies
cubn
Search, Listen and Submit
Marion/Johnson County, IN
During qualifying today I tuned to IndyCar Officials 451.200 and 452.125 during the very last car of the fast 6 qualifying.
I caught (unencrypted) CC 3 SL 1 TG 16777184 calling out white and checkered flags but I don't know which of the two frequencies VFO I was hearing that on.
Wraydio
While I'm a veteran of the 500, this is the first year I'm taking a scanner. I'm a scanning newbie in how to use an existing file to program my BC SDS-100 instead of doing it manually in Sentry. Can you (or anyone) coach me on transferring the file to my scanner?
TheMann00
I've not worked with that scanner- but this video looks promising, from what I'm reading in the description:
If it gives you a spreadsheet style of entering data- you might be able to either import my CSV file, or copy/paste the rows, or at a minimum, type everything in by hand, which will still be lightning fast compared to trying to program it from the scanner front panel itself. For importing or doing a copy/paste, you might need to rearrange my columns, add and remove some, to make it work. Might be best to read from your radio, and export as a CSV first, and compare the files, to see how to make my CSV look like the kind that scanner is expecting.
My CSV files are here: 2025 IndyCar Frequencies
glennhl
Mesa, AZ
I downloaded your new file that had both tone and no tone. However, on your no tone banks (5, 6, 7, 8) you have tone set to search instead of off that you used in your original no tone files. Which is correct?
TheMann00
Yes. I made this change. SEARCH is the same as OFF, where everything will get through. But when it does, it also flashes the TONE it hears in the transmission, so (if you want) you can take note of it, and update your other channels. This is how people find the tones in the first place, at least if they have this particular scanner. If you do nothing at all, but listen, it will function the same way as having TONE set to OFF.
cubn
What I found listening on Carb Day is
452.125 repeater CC 3 SL 1 TG 16777184 is used in the clear for important announcements while other users on that channel use TG 1003 ENC.
Note: I'm not hearing anything on 468.825 this year (I'm listening from Greenwood) but I have been able to pick it up in years past.
cubn
Anyone find race control on UHF analog for the Indy 500?
I only heard them on 452.125 CC3 SL 1 TG 16777184 but they also use that channel with ENC using TG 1003.
