saxsin
I have a 296d that is set to track Baltimore City police and fire. The settings used are:
Scan - Trunk On
Type - TypeII/P25
Delay - On
Activity ID - On
I-Call - On
Status Bit - On
End Code - On
Control channel - Off
Data Skip - Off
Apco card - On
SQ Mode - Tone SQ (have tried all 3 settings)
I have all of the freqs programmed, with 868.9500 as the primary. I have about 10 IDs programmed. The audio levels are set with the beginning at 533 (have also tried at 4, 6, and 7)
When I scan, the radio just stays on scan and never stops. If I bring up a channel manually, I can hear the traffic fine. It would seem that the radio is not recognizing the main channel, and as such is not tracking any of the other channels.
What am I doing wrong here? Is it a setup problem, a radio problem? My 996t tracks fine, and this radio is driving me mad! I recently did all of the updates available, and I was hopeful that would be the end of the problem...
Thanks in advance for any help you can recommend!
Scan - Trunk On
Type - TypeII/P25
Delay - On
Activity ID - On
I-Call - On
Status Bit - On
End Code - On
Data Skip - Off
Apco card - On
