Glad to hear you got it working.
Enjoy it for a while, but do look at building or buying a better antenna in time unless you can reach every station that's important to you.
The antenna and coax are the heart of a VHF/UHF system, the better they are, the more distance and less noise you will get.
I'm in a valley with three very tall mountains that no antenna I have tried will get signal over except for "Knife edging". This put's my signal way past the towns on the other side I'd like to talk to and gets me into repeaters at about 100 miles. That's the way knife edging works.
So I've decided to build just a small duel band antenna for the valley and the repeaters on the mountain and try a high gain beam antenna for getting more distance out of the open end of the valley. It's just too much signal from the high gain vertical doing nothing in the valley. I can point the beam where I want it and not put way too much signal in all directions that is not needed.
Making your own antenna is always fun, glad it's working for you, but do look ahead, plan and figure what will get the job done the very best for you. Every location is different, so no one set of rules applies to every place you transmit from. The higher you can get the antenna (within reason), having the best coax you can afford and keeping the run as short as possible all help as does keeping the antenna in the clear, away from buildings, tree's ect. An antenna analyzer is a great help in building and setting up antennas. If you plan to keep making your own and getting into HF, it's a worthwhile investment. The more you know about what your antenna is really doing, the better it will work for you.
If you are doing a lot of UHF, try to use "N" connectors if possible. They do cost more, but keeps the impedance of your feed line much closer to the ideal 50 ohms than the UHF connectors do. Many times it's looking at every little thing that makes for the best system. All of those little things add up and when you have your system as close to perfect as you can get it for your location will pay off in far better connections. There is nothing better than having many compliments on how good your station sounds, especially on long distance contacts.
Anyone can throw up an antenna and transmit, but I'm sure you have listened to that one guy who always sounds better than 95% of the stations out there. That is what you should strive for.
It's OK to have several antennas. The high gain vertical I have will stay up, just because the gain it has gives me good ears in all directions and there may be times it will work better than one of the others. The small antenna is perfect for local work, you don't want to use more power than what you need. The Beam has a lot of gain and of course is directional. In many cases, I can hear a weaker station with my high gain vertical, then point the beam at them and have a much better signal both ways. Also and read reviews on EHam and ask a lot of questions before buying or while making something, a lot of money is wasted buying lower priced things that just don't get the job done and some things are overpriced for what they deliver. Most of all, Have Fun !!!!!!!!!!!
73's John
