396 OPP Setup
CaptainD
Ontario
Have my new 396 up and running OK. Looking for advise on how to set up OPP properly. My local area works fine but I would like to set up other areas that I travel to. Also not sure how to set up Quick Keys properly. Any suggestions?
Thanks in advance...
Muxlow
Super Secret
Middlesex County
You can have 100 different systems programmed in that radio
The way i have it is each tower has its own quick key.
So for me chatham kent. I have all the channels for chatham kent only programmed in, and then what ever talk groups i have i split up into the 10 different qick key groups you can have.
So iv got 8 different opp towers in 8 different folders attached to 8 quick keys.
Since i cant get the london tower i dont have that quick key selected.
All the talk groups are the same just the control channel and all them are different for each tower.
If youd like i can send you what list of how i have it set up.
It really helped me when i got my radio it was programed and i read the radios mem and saved it. Now i got the hang of it... Its kinda hard to figure out or was for me anyways before i saw the file
LordJ
South-Eastern, Ontario
I have the tower that is closest to my area programmed in as a system under one QK (QK 1), and I typically ID search that tower. I have all the other towers that I may need in my travels programmed as separate systems all under the same separate QK (QK 9) and ID search them as well. Each system I have grouped into Group QK. Opp = 1 MOH = 2 MTO = 3 MNR = 4...So if I want to only listen to the OPP, I switch to ID Scan and lockout the other groups...hope this made sense..
