417.450
mkewman
Sacramento County, California
getting a bit of traffic on this frequency.
traffic like "inmate control, unit xxx 10-7 at sacramento domicile"
what is this freq? it's 417.45 with a pl of 144.8
also 417.200 with pl of 127.3 they have MDC1200 tones at the end of the transmissions and were talking about the removal of a van from a parking lot. using 10-codes (in this case 10-22, as the standard "cancel" code)
these both are being heard very clearly in rocklin.
gmclam
Fair Oaks, CA
I show 417.45 as being DEA tac B. I have no idea if that is what you're hearing or not. I'll program it in and see if I pick up what you're hearing.
74596
Elk Grove, CA
I did a google search of 417.4500 and one of the search results was for this webpage:
Code:
http://www.panix.com/~clay/scanning/Frequencies/Federal/DEA.txt
I'm not sure how up-dated that page is, but it might be useful to someone...
74596
Elk Grove, CA
I've started to monitor 417.4500 and I just heard some traffic on it. Not too sure who or what kind of "traffic" it was, but I'll try to keep monitoring the freq...
Sac916
417.2000 127.3 is Federal Police, with a small number of units in downtown sacramento. There was a thread about this somewhere recently. I'm off to work and can't search for it.
gmclam
Fair Oaks, CA
Yup I am hearing the traffic on 417.450 too as well as 418.750. I am surprised it is in analog, wow! I've now added about 20 freqs I have listed for DEA.
Sac916
mkewman said:
most traffic in sac is analog. theres a 170 mhz frequency that has digital traffic but i can't figure out what it is exactly.
170.2 or something? That's Fed Ct House downtown. I used to hear it in the "clear" before they went Digital Encrypt
gmclam
Fair Oaks, CA
Well "Sacramento traffic" may be analog, but it seems there is federal stuff which is not. I receive digital transmissions on 162.300, 163.200 & 164.600 - US Marshall. There is a lot of USFS transmissions +/- 170 MHz, and some is digital; but I am not sure if it is data or voice (I believe data).
The 144.8 CTCSS tone is not a standard or "sine wave" tone. It is also very close to the standard tone of 146.2, close enough that the two tones might not be distinguishable for many commercial grade radios. Are you sure this is the tone you received?
Are you hearing the digital USFS traffic on 170.525? That is the USFS Region 5 or Pacific Southwest Region data frequency. It is used for packet communications and for a system very much similar to the amateur radio APRS or Automated Position Reporting System. Fire apparatus and law enforcement vehicles are equipped with this system.
If I'm correct the former radio tech on the Inyo National Forest is the one who pioneered the use of packet and APRS on this frequency, which was later adopted for region wide use. He is a ham and was quite innovative in his approach to solving the communications problems the Inyo had. I worked on the Inyo for the last 11 years of my career and prior to that worked on a Ranger District on the Toiyabe National Forest for 7 years that bordered the Inyo on the north. I followed what he did for 18 years. The Inyo's trail crews often had a great deal of radio traffic as they would set up camp for many weeks and needed to relay personal logistical traffic as well as long supply lists and it would tie up the Forest Net for half hour periods or more. So the radio tech set up a packet system to keep this traffic off of the Forest net. The Inyo has a lot of very large wilderness areas.
He also set up the APRS and computers in dispatch for obvious reasons. When we replaced the old Motorola crystal handhelds, he placed them in surplus military ammo boxes for use as portable extenders to solve coverage problems in areas that were blind to any of the mountain top repeaters. Some of these extenders were put in every year in the same places and some where put in when a large trail maintenance project was going to be done in a blind area.
He rarely surplussed out any radios or parts and his solutions to some of our communications needs cost almost nothing. He was also very good with computers and obtained quite a few of them from the surplus stock of the military and used them for specific applications for the Forest's communications system. Obtaining the military surplus radio parts and computers only cost us his travel time to the Bay Area to pick it up. He probably saved us enough to pay his annual salary most years. What was his reward for doing this for 32 years? The current presidential administration "outsourced" all radio system maintenance the contractor cannot even tell anyone what frequencies the Forest uses and has not been able to get the Forest's Administrative Net working after three years, which had only been partially completed, but had all the components purchased, at the time of the Forest Service radio tech's forced retirement. This due to the wisdom of the administration of the village idiot from Texas!
gmclam
Fair Oaks, CA
I do not have 170.525 programmed.
