xg100p program cable
radiotech33
County line road
part # 12082-0410-A1....7 in stock...
octet-stream;base64,W3swMDAyMTRBMC0wMDAwLTAwMDAtQzAwMC0wMDAwMDAwMDAwNDZ9XQ0KUHJvcDM9MTksMTENCltJbnRlcm5ldFNob3J0Y3V0XQ0KSURMaXN0PQ0KVVJMPWh0dHBzOi8vc3RvcmUubmV3bG9uZG9udGVjaG5vbG9neS5jb20vDQo=
try this New London Technology Online Store
search part # this in earlier post to find the Item
KJ6PJY
Monterey, CA
Does anyone have accessory connector pin-out for XG-100P? Thanks for cable source.
RFguys are out of stock :cry:
natedawg1604
Colorado
I ordered something from the RFguys almost a month ago, I've been emailing them for an order status and received zero response, and no info on their website. I'm about to file a dispute with my bank, it sounds like they are a pretty crappy company, they don't even have a phone number.
n3obl
ØAES-1024
PA
Going to spend big bucks on a radio but cheap out by trying to pinout the cable. Homemade cables are sure way to brick a unit.
KJ6PJY
Monterey, CA
I am not trying to make homemade programming cable I am just trying to get the pin-out so I can use my aviation head set and other accessories through the quick disconnect Hirose adapter. I did order cable from New London technology for about $170. They had 6 more in stock at the time. BTW you can brick your radio with any cable if you dont know what are you doing but I agree making a cable after spending multi K $ on the radio makes no sense.
TDR-94
That's not uncommon for RFguy's. Some people get burned others get their cables.
wa8pyr
Staff member
Lead Database Admin
Ohio
I disagree. I’ve used home-built cables for years; same pin out, exactly the same wiring as a factory cable but only cost me $5 worth of parts instead of $100 plus for a name. Never had a lick of trouble.
It‘s not so much being cheap; it’s more along the lines of not wasting my money paying 20x the value of something simply because of the name when I can have the satisfaction of building it myself/
Reconrider
Inside the Galaxy
Radio Galaxy
Would you say it's better to make the xg-100p update cable, or better to buy it?
IFRIED91
Arrive alive
NYC area
I’d save the headache and cough up the dough… but that’s just me… also the fear of bricking a $1000+ piece of discontinued equipment gives me nightmares
radiotech33
County line road
I have made cables before for myself from LPE all the way to XG75 and never had a problem. But I think the XG100p cable is a different animal...Because of the UCD connector...So I got the OEM no problems and works wonderful
