I don't think so. DMR uses 12,5 KHz modulation bandwidth as standard and the ships with SFM DMR sounds at about half the volume when listening in analog to the data modulation. They are using duplex repeaters and not simplex.
Most of the DMR systems in my area use a bandplan that has 12,5KHz channel steps with a 6,25KHz offset that would make it start at 420,00625MHz and next channel at 420,01875MHz and then continues with 12,5KHz steps.
dPMR are using 6,25KHz bandwidth and Whistlers TRX-2 decodes that and also show the mode on the display but Uniden scanners doesn't react to it, but I'm not sure if Uniden scanner even handles that digital format.
Also when there are 6,25 NXDN or IDAS a Uniden scanner struggles with that when the modulation and demodulated audio levels are so low. Uniden really needs to add a SFM mode to their modulation types that increases the audio level in the DSP.
/Ubbe
