JimD56
KO9JAD/Fire Lieutenant/Paramedic
Davie, FL (Miami/Fort Lauderdale Metro)
Ok, the Shack with the Zetron Model 27 Receiver Monitor is Complete. Purchased "BRAND NEW" with all parts and connections off of eBay.
I'm so glad I went with the Model 27 vice the music/DJ style previous Mixer. The sound quality/clarity is amazing and the "Blinking" active and "Solid" Mute LEDs are great.
My old setup used to be a "Digital Side" vice an "Analog Side" well now I call it an "Active Deck/Side" and a "Static Deck/Side".
The "Active Deck" are the items I have to adjust or fiddle with and can NOT be controlled via PC, it's right up front against my keyboard.
1) Zetron Model 27 Receiver/Monitor - 6 Sources Coming In (2 Open for Future Use) like my SDS100 once another patch cable arrives. It's mounted in a 3U Box from Pearson Cases off of eBay. Since it's 3U and I used to have a 4U here, I now have room for the below radios.
2) Yaesu FTM-200DR - Local and Statewide Ham, Florida SARNET, and Marine specifically, I'm 8 miles from the beach. This is my "bugout" radio as well. I have a backpack and a specially built frame set up for it with a battery.
3) Motorola XPR5550e - DMR Only. (Programmed for Receive Only) I am surrounded by DMR "stuff" so much so that I will not dedicate a scanner to it. This XPR was cheap on eBay. It's programmed with a ton of Local, State, and Feds Government agencies, Airport Services, Private Ambulances, Private Utilities, Son's High School, etc.
Both these radios' sound goes through the pictured Yamaha Studio Monitor Speaker and not the Model 27. Excellent audio from the Yamaha.
The "Static Deck" I don't really have to mess with except maybe sometimes locking out a channel or volume.
This side is all PC Controlled through ProScan. This is my previously used 4U Pearson Case stacked on a 2U case.
1) Top Left SDS200 - ALL Local Simulcast 700-860mhz. PD/FD Fort Lauderdale and Miami ALOT of Simulcast Nothing Encrypted, 5.5 million people metro area.
2) Top Right BCT15x - Aviation 4 Airports Monitored, Mil Air, Mil Ground, Misc. Local/State/US Government VHF/UHF Non-Ecrypted.
3) Middle Left Motorola XTL2500 - My Agency Dispatch Channels
4) Middle Right Motorola XTL5000 - My Agency Tactical Channels
5) Bottom Right BCT15x - Broadcastify Feed using ProScan Radio Feed
6) Bottom Left BCT15x - Broadcastify Feed using ProScan Radio Feed
Portables on Top of Box
Left Motorola XPR7550e - My Agency and DMR Private Ambulance
Middle SDS100 - Listening to the same as SDS200, they are both very busy all the time.
Right BC125AT - Weather and will program on the fly for whatever I need heading out. Airshows, etc.
Antennas
1) VHF/UHF Tram Ham 200 watt max for the FTM-200DR in the back of the house out of sight of the HOA.
2) Laird Mobile 700-900mhz with Base ground plane kit into a Eberline EDA2200 2 Port at +11db per port for SDS100/200.
YES, it's on the same mast as above but I do not transmit with SDS100/200 on.
3) Tram VHF/UHF Discone in Attic out of sight into an Eberline EDA2800 8 Port +4db per port for the XPR5550e, XTL's, and BCT15x's and 2 SDR Dongles.
Well, that's it...for now.
JimShack Aril 2023 1.jpgShack Aril 2023 4.jpgShack Aril 2023 2.jpgShack Aril 2023 3.jpg
KC1UA
Scan New England Janitor/Maintenance
Marstons Mills, Cape Cod, Massachusetts
Outstanding setup! Nicely laid out. I love the ultra-wide monitor as well. Where do you get your rack enclosures? The panels for the scanners look like Alberta Radio Supply, which is where I've gotten many of mine. Nicely done indeed!
maus92
The OP
Did you modify the openings to fit your scanners, or can Alberta do custom openings?
evilbrad
My head makes a bad antenna
Jim I bought a few of the Same amps you use for when I finish with outside antennas. Plus I have 3 4 port stridsberg and 1 8port stridsberg
JimD56
EBAY - 3 Foot SMA Male to F Male Plug Coaxial Connector Type Pigtail Jumper RG316 Cable
I use standard TV Cable for all my "receive" only antennas.
The pigtail goes from scanner to the heavier gauge cable.
You never want to connect heavy gauge cable or large connectors to an SMA Male or Female it will damage it.
markspoo
Chicago
shack-aril-2023-4-jpg.139384
Would you be so kind to elaborate on the speaker in this photo. Who makes it where can it be found etc. Thank
JimD56
On the left is a Single Yamaha MS101-4 Desktop Powered Studio Monitor bought from Amazon (Used) and on the right a Zetron Model 27 Speaker Selector for 8 Input Devices. The Model 27 hasn't been made in over 25 years, and is discussed in numerous forums.. eBay is your friend.
N1SQB
Somewhere On Earth
Excellent set up! If you notice on my avatar, I have a similar radio rack set up. I need to get the faceplates to mount my 2 XTL2500s ( VHF/UHF-400-512) I got my faceplates from Alberta as well. Very nice job overall. Congrats...
PS- How are you powering your XTLs?
JimD56
Astron 30 Amp Power Supply and an 8 Port Anderson Power Pole
