5500 Programming Problem
kmacinct
Connecticut
I'm trying to update our radios..
We have multiple 5500's in various bands. They are all the same generation radios and set up all the same way.
I have successfully connected to and updated both low band (33mhz, 46mhz) and the VHF High (155) band radios with no problem.
I cannot even communicate with the UHF Radios. I have tried every UHF "Band" possible (Althought I'm fairly sure it's UHF-D)
Any suggestions?
Kevin
Connecticut
midstate33
Gassaway, WV
If you have the current information (freqs etc that are currently programmed in unit) there are a couple ways to possibly get things going, you can go in the file and click on New then read the radio, if that does not work then go to the default file it should say default uhf or defaultu, this will program the unit to
the factory defaults, then you should be able to reprogram to new freqs etc, normally if you can do lowband & vhf the uhf works also but I have seen similiar problems but not in the 5500's, did you try more than one UHF unit or are you having trouble with just the one UHF unit???If I can help feel free to contact me via email at: midstatecommunications@verizon.net......good luck...Fred
