700-800Mhz vehicle antenna
lu81fitter
Marshall County, Illinois
If you have to go with a mag mount, get an NMO mag mount. If you are strictly looking for 7/800, a short 3" whip will work just fine. Or you can get a multi-band from Laird or Larsen. They work quite well also. Check these out.
Magnetic Mobile Antenna Mounts | Antenna Farm (theantennafarm.com)
Laird Technologies QW760 - $9.95 : The Antenna Farm, Your two way radio source
Larsen NMO150/450/758 - $49.95 : The Antenna Farm, Your two way radio source
Laird Technologies ABSCANC - $29.95 : The Antenna Farm, Your two way radio source
A permanent NMO mount works and looks much better.
trentbob
W3BUX- Bucks County, PA
Good answer. If you absolutely must have a magnetic mount then that is your choices. A quarter wave 3 inch whip or the Larsen tri-band. The one shown in the above post is the new one with the spring in the heavy-duty amount.
In the event you ever want to listen to a VHF high or UHF frequency you've got coverage. With the quarter wave whip you only have 7 - 800 megahertz.
hill
Middle River, MD
I have same quarter wave, as linked, but just purchased the black version of it. It works so well on a trunk mount on 700/800 that I purchased a second one to use at home on small mag mount.
hill
Middle River, MD
If you really must use mag mount would go with a Larsen or Laird model. The Tram is low quality ham/hobby brand the two others are much better and are used in commercial and public safety.
Which mag mount did you buy with the Larsen triband?
Will this one work? I'm just a hobbyist, not commercial.
Tram 1233-BNC
The Tram mount is probably just fine, but I've personally found that their skill in crimping coaxial connectors is extremely lacking.
If you know how to install coax connectors, you could chop off the Tram one and install your own and have a decent setup.
Or, better yet, go with a quality mount made by a company that knows how to install connectors:
For the few extra bucks, it's really worth getting the Laird.
CanesFan95
Analog already is interoperable.
FL
For just 700/800, you might consider a more band-specific antenna. I got this one that has some actual gain and it's excellent:
https://www.theantennafarm.com/catalog/pctel-maxrad-bmax7633s-6515
I also got one of their mag-mounts where you can customize the coax length and connector, but they are bit pricey:
https://www.theantennafarm.com/catalog/index.php?main_page=index&cPath=264_265_1510
Instead of RG-58, you can put a note in the checkuot comment to ask them to use LMR-240 for lower loss.
