780xlt/796d cloning?
n5bew1
norman, ok
Has anyone tried to transfer the programing from a 780xlt to a 796d?
I bought a 796d and was just wondering.
jaymatt1978
Cape May,NJ
It can't be done scanner-to-scanner because the memory architecture is completely different. The only way to do it is with software even then it would take multiple steps
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
You could migrate the data using Scan Control. Klunky software, frankly, but this is one of its unique functions. I believe ProScan could also do it
The 796 is not a DMA scanner, by the way
Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Dynamic Memory Architecture. The memory scheme used by many of the newer Unidens. Essentially put there are no banks - you allocate your own using a very different scheme than the limited and sometimes wasteful bank technology...best regards..Mike
n5bew1
norman, ok
Thanks I did do some searching and found out what DMA is. For what I listen to a non DMA scanner is easier to wrap my head around. That's why I liked the 780XLT so much as it does what I need it to do as I focus on a specific system. I tried a BCT-15 and couldn't make sense of it and sold it.
Thanks for all the help.
ProScan
Software Provider
Ontario, Calif.
As ka3jjz pointed out, ProScan can do it.
1) Set ProScan to 780 scanner type.
2) Create a new database and download the data from the 780.
3) Save the database file.
4) Set the ProScan scanner type to 796.
5) Create a new database and import the database containing the 780 data.
6) Upload to the 796.
n5bew1
norman, ok
If i get Proscan will a USB to serial port adapter work so I can use my laptop on the 796d?
n5bew1
norman, ok
Got Proscan and did the database migration thing mentioned above and it is working. I've got to do some tweeking but I am hearing P25 transmissions now.
