Anything in that range there... 800 all the way up to 1300Mhz...
What/who would normally use these frequencies?
Here is the reason why I am asking... I posted this in another section but I also think possibly you guys have more information on usage, etc...
I have recently purchase/installed/currently use a Kenwood D710A as my mobile unit.
It is running with a Comet SBB5 NMO antenna with a 5" mag mount.
Now here's the rub... the antenna works absolutely excellent on 144 and 440 and all other stuff in that range....
However the radio has a mode where you can also monitor 800Mhz on up to 1300Mhz roughly is the range.
Now my question is, with my current antenna could I still listen in on those frequencies? Or would I need to get another antenna (or two) for it?
To the best of my knowlege no one in my area uses 800 to 1300 Mhz but in other cities around from what I hear they do.
I am a brand new HAM so really and truly are these 800-1300Mhz generally just law enforcement bands or what?
For you guys though, who/what is the normal use of the 800-1300 Mhz frequencies?
FYI I am near Houston.
