800Mhz LPE Replacement PA kit
mleeb1
Bakersfield, CA
I have a LPE 200 System Model with no RF power out, I have aquired a couple KT-008364 Replacement PA kits and have install with no luck. The replacement PA only has 4 leads while the original has 5. It appears the missing lead on the circuit board is +8.5 volts DC. Has anyone installed this kit? any pointers? Am I missing something?
Thanks for any information.
yankeephill
Clayton, NC
Once you replace a PA in the LPE, special software is required to recalibrate the power .A MACOM shop should be able to help you out.
mleeb1
Bakersfield, CA
I do have access to the Radio maintenence software,Programmer and RPM. Does anybody knkow the steps to recalibrate power?
Doink
I hate to tell you but only about 1/2 of the LPE 800 low/not tx power issues I have seen (quite a few) have been the PA. The driver chips (a small six pin SMT chip) are prone to failure as well as broken diode connections in the variable bandpass filter.
