I am using the ARC-XT Pro software to load my frequencies into my Uniden 996XT.
The front port does not work ... so I am using the rear port ...
I have used my cable in the past on other computers.
My problem is when I go to the "Scanner" heading at the top of the software ...
Then scroll down to the "Communication Setup" prompt
None of the ports are highlighted to select ... so I choose the "AutoDetect Scanner" option.
My Baudrate is set at 115200 (I have also tried the 57600 option) on both the scanner and the computer software.
Error Message: "Software has not detected your scanner, please check scanner is switched ON and connected."
(Read instructions how to setup scanner communication)
I am looking for suggestions .... or assistance on how to clear the Universal Serial Bus controllers
