A couple more XTS3000 questions
W4KRR
Coconut Creek
1. Will a beltclip from an HT1000 battery fit on the XTS3000 battery? It looks like it might, but I sure can't get it to fit.
2. Can the XTS3000 be programmed for a user selectable scan list, similar to the HT1000 or JT1000? If so, how many personalites can be scanned at once? The way mine is set up now, the scan lists are pre selected in the software, and you can turn scan on or off, but the scan lists are fixed, and you cannot add or remove personalities (channels).
Grog
Banned
West of Charlotte NC
If you can't get it to fit, that should be a big clue that it's not supposed to go on there. No, it does not take the same clip.
In conventional it is supposed to scan up to 16, trunked is 10.
If it's not your radio, and they set it up so you cant change the scanlists, maybe they know better than you? They did pay for it and decide how it should be used, right?
W4KRR
Coconut Creek
Actually, sometimes people do have trouble with getting things that ARE supposed to fit; I thought maybe a possibility was that the battery slot or clip were damaged. So now I know that's not the case.
There isn't any "they". It's my radio.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Different part.
Yes, they can be setup so you can change them on the fly.
Conventional scanlists can have 16 personalities and trunked scanlists can have 10.
