BOBRR
Hello:
Brand new user, and relatively unsophisticated re scanning.
Would sure appreciate some help with the following.
a. Really concerned about blowing something by doing something dumb; hence
this question:
The manual really isn't very clear on this -
My understanding after reading it is that you can (also) use the rear 9-pin 232 port for connecting the 996 to your PC for operation with the Uniden software, rather than the front connector. Either would be just as fine.
The only caveat apparently being that you need a null-modem cable (as contrasted to the 780 usage , e.g.) if you do use the rear port.
But I have also heard that this rear port is ONLY for the gps operation.
Can I use this rear port safely to go to the PC ?
If so, do I need the null type of cable ?
Any thoughts on this would be most appreciated.
b. I downloaded the UASD software and got it installed with the Key, I believe O.K.
But, there's now a Folder on my Desktop labeled BCSS.
I used all of their default locations, and didn't change any.
Where should this folder actually be located ?
When I put it where you suggest, should I just put the complete folder there, or only the contents of it ?
c. Regarding all the aero. and other freq's Uniden pre-installed.
Where can i find a listing, in UASD I assume, of what's actually in there ?
I can find the listing for my locale, Boston, but not the aero. freq's, e.g.
Thanks,
Bob
this question:
Thanks,
Bob
