A little confused
bowser22
Hi guys, I'm a little new with my gre 500. I was succesfully able to listen to mixed mode systems and listen to RCMP. I'm confused about all this TSYS TGRP nonsence lol. I created a TSYS and called it Aliant Trunked. Because its the Aliant TMRS for my province. I then created TGRP's that are assigned to this TSYS. Heres where I'm confused. I looked up all the repeater frequencys for different areas and I'd like to enter those in to get better reception and sort of roam throughout different repeaters whilst I travel, I can receive 3 of these towers very clearly but I'm wondering do I have to create a seperate TSYS for each area and program in the respective repeater frequencies? Or can I just program in a bunch under one TSYS and keep the TGRP's assigned to just one TSYS. I really hope im not confusing anyone.
Thanks!
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Assuming you mean Aliant Trunked Mobile Radio System (TMRS) Trunking System, Province-Wide, Multi-State - Scanner Frequencies. Program up to 32 red and blue frequencies (Controls and Alt Controls) per TSYS. Match TGRP's to each TSYS.
You may desire to program a TSYS and use talkgroup associated with that frequency grouping. Then program subsequent TSYS/TGRP listings. All TGRP's can be in same scanlist but they must be tied to a TSYS. However, this scanner may be best used by setting TGRP's to scanlist by agency of use.
A programming shortcut for scanner can be found below my signature.
bowser22
okk i kinda get it. I can program a bunch of frequencies for different counties under one TSYS then program in my talkgroups and group by agencies through the use of scanlists.
fmon
Eclipse, Virginia
Not Counties but Towers of a system (TSYS) if you're using the reference in my previous post.
The programming shortcut is fairly clear on how to program. Your system (TSYS) is not VHF/UHF so ignore anything regarding them.
CBFD
Pleasantville Nova Scotia
I put all 32 cc in each tsys and then load each agency TG's...
so bank 1 is all police and bank 2 is ehs and so on...
also I sell these rigs and program them as well and Im close to Bridgewater NS if you need help in the programming.
email me littlemac@eastlink.ca
