Accessory/Ext speaker hookup on Maxtrac
kadetklapp
Indiana
Sometime ago I bought a two-channel UHF maxtrac on Ebay for our wrecker business. I noticed the ot her day that the speaker isn't working. How can I wire an external speaker to this radio (which I'd rather have anyway)? I didn't see any readily accessable plug on it, so would i have to crack this thing open?
bdub5
That one guy...
Hancock County, IN
Ext Speaker Pin
You can attach a ext speaker to the radio. You just need to know which pin to attach the speaker to. It depends on if you have the 16 pin or 5 pin bus on the back of the radio.
Check out the following link for this information. You will see links in the first couple paragraphs for 16 pin and 5 pin connectors. Click on the link and it will show you which pin is the ext speaker.
http://www.batlabs.com/maxrad.html
I hope this helps.
kadetklapp
Indiana
Hey thanks a lot! Looks like I'll have to connect to pins one and sixteen in order to get 'er working. Now I need to fashion a plug somehow I reckon.
Josh
Auburn Hills, Michigan
You can either buy one from Moto/ebay/whatever
or use a computer IDE cable.
obijohn
If that Maxtrac has a 16 pin accessory connector, then you might check to make sure the plug didn't get knocked out. The accessory plug has to be plugged in because there is a jumper that has to be in place for the internal speaker to work.
You can get an accessory plug kit from your local Moto. RSS.
kadetklapp
Indiana
Ok, I don't have the female plug that actually attaches to the radio. I bought it off ebay with just the power cord and mic. So I need the plug to activate the speaker at all? That does help. Anyone have a Part Number for the sixteen pin plug? Thanks!
obijohn
The easiest thing to do is just get a computer header jumper (.100 pin spacing) and install it over pins 15 and 16 on the accessory connector.
