kc2klc
I've been using a roof-mounted VHF/UHF discone for ADS-B reception with moderate results. I decided to purchase this dedicated ADS-B antenna (at under $30 who could resist?): 1090MHZ 36DB SMA Active ADS-B PCB Antenna with Biaser Tee Kit
The antenna element is a circuit board that appears to be this one: ADS-B 1090MHZ Gain 2.0dBi Antenna Receiving Aerial Aeronautic Facility Spare Parts for DIY Self-Made Expreiment
It has a (purportedly) 36 dB preamp built-in. Despite that, I think I should keep the coax length as short as possible to avoid loss. I'm wondering if I can put this in my attic? The roof consists of thin (probably about 3/8" / 9.5 mm) particle board overlaid with standard asphalt roofing shingles. It wouldn't be near any plumbing, wiring, gutters, or other metal infrastructure. Is there any chance that the roofing materials, which I would assume are non-conductive, would substantially attenuate the 1090 MHz signals? Are there other concerns I should have?
Thanks for any advice on this!
