Alias IDs
beerad4
Springfield
Hello!
Has anyone figured out how to set the alias’s with the frequency ID? I think I found where to do it, but can’t get it to work-
thanks!
N6ML
Yes, it works for me. Just add entries on tab D5 under "Member List Setting"
N6ML
Actually I just reread your question - I may have assumed you meant something else. What do you mean by "alias's with the frequency ID"?
beerad4
Springfield
I was under the impression that with this new update we could name for instance a particular vehicle number (example Medic 1) with its mobile radio MARCS ID number.
I probably misread the update-
N6ML
OK, so radio (or subscriber) ID, not frequency ID :) That's what I assumed you meant. See my earlier answer.
beerad4
Springfield
N6ML-
Ok..so just for clarification on my part-
So in my example, if Medic 1 has a mobile radio MARCS ID of 2990045, am I able to label that number as Medic 1 so that when the unit transmits it comes up as Medic 1 on the display?
Hope I explained it correctly. Thanks for your patience. Kinda new at this-
N6ML
Yes. I haven't tried it on MARCS, but I don't see any reason for it to not work. You should just need to add an entry to the Member List Setting with "Medic 1" for the Call Alias and 2990045 in the P25T column,
radio3353
Where does one find the radio or subscriber ID? This is what I get on my G4 screen when a call is received. Obviously, the alpha-numeric character shown will not go in the P25T Column in D5. Thanks.
89868
kikito
North Pole, Alaska
The far right tab at the top of D5, called 'Member List Setting' is where you would enter an Alias for the alphanumeric hex radio ID shown of 429D80.
radio3353
I know, but this is what I get when I enter 42D52A1 (not 429D80 which was just what was showing when I took the pic) as HEX. It does not work. Does that look correct to you? Thanks.
89878
N6ML
That's too many digits - subscriber IDs are 24-bits, so 6 hex digits - I think you misread your display.
kikito
North Pole, Alaska
I just tried it and got the same result as you. Maybe because Hex IDs shouldn't exceed more than 6 digits? The 429D80 works but not the 42D52A1.
radio3353
Thank you both for your help. As soon as dispatch transmits again I will double check the ID. Hopefully it will be 6 digits and the problem is me. :oops:
Edit: Working as expected now! I mistook the last bracket sign as a 1. Thanks again for your help. And, thanks Unication. This is a nice feature.
jpb
Great feature... soon. I have a lot of aliases to enter. This desperately needs a CSV import feature. @Uni1 , if you folks could allow us to export talkgroups, group IDs, etc., to CSV, let us sort them and reimport them (making sure existing entries remain linked to relational tables), it would be amazing. Anytone's AT-D878UV software nailed the concept.
lsh1885
Orlando, Florida
I have used it since the update and it works good. I just wish there was a database for subscriber ids somewhere it would be easier than reading them off the pager. Wiki has a database but it is very limited. I am looking forward to TG delay when Unication come out with that.
radio3353
A database of every radio in use? How would that even be possible?
lsh1885
Orlando, Florida
Well I would not say every radio but I am thinking more than 5 or 6 which is what Wiki had but your right it would be impossible for every radio in use.
I have 304 programmed into the pager I suppose that's enough!
kikito
North Pole, Alaska
I wouldn’t push that “issue” on today’s climate. That would be another EXCUSE for the powers that be to justify more of our tax money to go to encryption and other obfuscation. But I digress...
