Amherst NY Police Dept?
mjfruth
Cheektowaga, NY
Long time lurker, first post.....
I searched, here and on other forums, and listened, and scanned.... And no luck. Where did the Amherst PD go to? The frequency listed in the DB is inactive, and there are no feeds active on Broadcasting.
Any ideas?
Sent from a device without a rotary dial....
nyemt774
Western Upstate NY
Amherst, NY PD
What I believe has happened is that there is no Longer I feed provider for the Amherst PD..That goes for most of the Law enforcement feeds in Erie County. Keep looking occasionally, maybe someday someone else will set up a feed...
ak716
'Merica
Im monitoring them right now on their posted freq in the DB, they are still active on whats posted
mjfruth
Cheektowaga, NY
OK, thanks! I guess it's time for a higher antenna. I foolishly assumed that because the posted Fire Dispatch was booming in here I should at least hear something on the PD Freq.
Mea Culpa....lol
ak716
'Merica
idk if its your antenna or settings, because I'm in the south towns using an okay (nothing special) antenna, and getting them crystal clear. id rule out your programming and your pl/dpl tones first (if you haven't done that already)
mjfruth
Cheektowaga, NY
It must be my location....I cannot hear them on 3 different radios - a base and two handhelds. I'll try it again from a different location with a handheld next time I go out.
Thanks!
dave3825
Suffolk County NY
Thanks!
Did you try all 3 without the pl/dpl tones?
mjfruth
Cheektowaga, NY
Yep....no joy....I even tried it on my SDR setup.....I'm not even seeing a blip on the spectrum analyzer or the waterfall display. Weird, I might be in some sort of shadow.....
Sent from a device without a rotary dial.....
