It kind of depends on what you are looking at. If you are looking at a RadioShack TV antenna amplifier, it will probably not be very low noise and - as others have pointed out - will probably cause more signal degredation than clarification. However, if you were to step outside of the "consumer grade" amplifiers and look more at commercial-grade equipment, you may have better luck. Lots of trunked radio systems, say in the 800 MHz band, use tower top amplifiers and receiver multicouplers that provide overall receiver gain in the system and have excellent performance. See what you can find on EBay, if you're willing to invest the money in it. Otherwise, as others have pointed out, lower loss coaxial cable and higher gain antennas may be a better bet and cost you less money.
