Multi-antenna arrays are very tricky, as different frequencies will react differently. The suggestion that you use an omni is good advice. And the 33 degree beam is no problem. The only time it could create a problem is when its very high in the air, and then you lose some effectiveness on the ground below.
Case in point; our ham repeater on 443.625 in Lima used a Decibel Products DB-420. Lots of gain. The signal was great out to 12 miles on a handheld radio, but if I walked around the neighborhood 2 blocks from the tower, I would be in an out of the receiver. The beam was overhead and not at ground level.
So for your antenna to be 3db gain and a 33 degree beam width, and assumed not to be way up high, your antenna will be fine.
