Antenna help!
squall8ball
Melrose, FL
ok so here is the set up, i have a sdr, 75 feet of rg8x cable ran outside onto a pole 40 feet up connected to a Tram mag mounted antenna (yes yes i know mag mounts are bad, but it was in my budget). Just before this it was on top of my tin roof of my house and got amazing signal, now nothing since i moved it to the top of the pole.. what am i doing wrong?
squall8ball
Melrose, FL
If you are going to put a mobile antenna on a pole you have to use a ground plane kit.
Until you can afford or get the correct equipment you would be better off putting it back on the metal roof.
Already have one on the pole from the previous owner of this house who used it for a mature radio as well.
FKimble
Newnan, GA
Did you use the same 75' piece of RG8x when the antenna was on the metal roof or did you go to the longer coax when you moved antenna to the pole? 75' of RG8x equals about 3.3 db loss.
Frank
W3DMV
Gettysburg, Pa
I agree with WA0CBW, don't see any antenna. I've never seen fiberglass ground plane radials? Do they have wire or other conductors (foil) inside
the fiberglass?
