Antenna help
desmoduc748
Hello, I am adding a President McKinley SSB/CB radio to my truck, I already have a Midland MTX-275 in it with a midland ghost 3db antenna attached to my roll bar pretty much dead center slightly above the roof line. Been tearing out my hair on where to install (and which length as well) the CB antenna. Do I add it to my roll bar (removing powder coating for ground) and get a 2 ft antenna (garage clearance) or put a 4 ft one and mount it on the rear of the bed? . I measured the clearance into.out of the garage and its just over 2 feet for the roll bar and just over 4 feet for the bed. I did plan on using a spring for either install point for added flex. Any help would be great, thanks all
desmoduc748
was
Mount the antenna on the roof with an nmo style mount. Can’t beat the performance.
I am trying to avoid drilling into the roof. Mostly because I don't trust my skills. Roof still leaves me with only 2 ft of clearance (give or take a few inches)
was
Here's one of the better Jeep installs I've seen. This guy had similar challenges. Installed a CB, GMRS and amateur radio.
