Antenna Installation in SW Ontario
Gymbag
Oxford County
Looking for someone in Southwestern Ontario to install a NMO mount into the roof of my Honda Ridgeline. If anyone knows someone please let me know. Thanks in advance.
gary123
You should be able to get BearCom to install it or MRC. It will go a lot easier if you already know where to route the cable and what connector you want on the end.
sirsmiley
Ontario
Just remove the handles on each side of the headliner of back seat. Pop off the plastic trim with hands or plastic pry tool. Pull the headliner down and then tape off where you want to drill and use a step bit to avoid going too large or too deep. This entire process should take maybe half an hour. Then install the mount and run your cable to where you want and reinstall the trim. Crimp on your required connector and screw on your antenna.
Total job maybe an hour or so.
Gymbag
Oxford County
You should be able to get Bearcom to install it or MRC. it will go a lot easier if you already know where to route the cable and what connector you want on the end.
Who is MRC?
Are you volunteering to do the job lol
gary123
MRC is a Radio Shop in the London/Kitchener/Guelph area. I just checked and it looks like they got eaten by Bearcom.
