I really appreciate all the help that has been provided. This weekend I will be installing a Ferret antenna using two of Radio Shacks's 4" side building mounts. The antenna itself weighs about 4lbs and appears as a single rod 8 ft in length and approximately 1 1/4" in diameter (looks like a grey broom handle). I had planned on using two 10 ft Channel masters steel masts which would give me a 20 ft mast. A friend advised that this mast would suffer too much torque in very high wind for the attachment points to the building and would eventually loosen. Another friend suggested that the antenna profile would create little wind resistance and the set-up would be okay. My objective is to get height.
Do you think that a 20 foot mast only supported by the wall brackets will be okay or do you think I should go with a 10 foot mast. The brackets will be about 2 1/2 feet apart and lag bolted through the exterior siding into the plywood sheathing. All but 3 or 4 feet will be above the roof peak and guide wires are not an option.
Thanks -
William
Thanks -
William
