scannerbum
Is there a meter to measure the amount of signal an antenna is receving ? If so , how much , where to get one , and can it help with antenna location , type ect...... ?
scannerbum said:Is there a meter to measure the amount of signal an antenna is receving ? If so , how much , where to get one , and can it help with antenna location , type ect...... ?
Before you spend any money, try comparing the squelch setting to block a given system.scannerbum said:Is there a meter to measure the amount of signal an antenna is receving ? If so , how much , where to get one , and can it help with antenna location , type ect...... ?
kb2vxa said:Hi Bum and all,
First the bad news.
"Is there a meter to measure the amount of signal an antenna is receiving?
Yes, a wave meter is exactly the thing. It's a calibrated receiver that reads out the signal in microvolts. Another thing is a spectrum analyzer which also has other applications and is a bit more difficult to set up and operate.
"If so , how much?"
More than you care to spend, for a few thousand dollars think of how many scanners you can buy.
"Where to get one?"
Being professional test equipment you'd have to look at suppliers of lab grade instruments. A "calibration house" is where you can find refurbished surplus gear at a lower price BUT still you're looking at around two grand.
"and can it help with antenna location , type ect...... ?"
That's exactly what they're used for among other things.
Now the good news.
There are plenty of receivers (not scanners) that cover the frequencies you want that have S meters which tell you the relative strength of the signals. Unlike wave meters and spectrum analyzers they're not calibrated but "good enough for government work". VHF/UHF ham transceivers have extended receive that covers adjacent bands but not everything so a good communications receiver with the proper plug in converter modules would be your best bet at around $1,000 to $1,500.
"The thing that does what you want is a signal strength meter, built into some scanners."
OK but sloppy, still it's a meter and better than nothing.
"Before you spend any money, try comparing the squelch setting to block a given system."
The degree of "sloppiness" depends on how broad the squelch is. If you have a "tight" squelch it's passable but doing it that way on my BC796D is futile. Good idea though and well worth a try.
"The best tool for this is a switchable attenuator."
Here we go again. N_Jay, an attenuator is useless without a calibrated receiver and where are you going to get one of those?
"Usually comparative readings are good enough."
As compared to WHAT?
"The issue is calibration."
Well, you always manage to get ONE thing right even if the rest is rubbish.
"The above attached post will be Humorous, Sarcastic and/or Accurate."
That much we ALWAYS agree on, you're a walking contradiction and misleading by purpose and design.
If you're trying to compare different antennas and mounting locations, the easiest route is to run the receiver's AGC voltage to a digital voltmeter. The higher the reading, the better job the antenna/location is doing for you.scannerbum said:Is there a meter to measure the amount of signal an antenna is receving ? If so , how much , where to get one , and can it help with antenna location , type ect...... ?
Hey, don't be giving away all my secrets!Remember how direction finding can be done better by nulling a signal, than by trying to detect a maximum peak.
