antenna mounting question
kc9neq
Illinois
i want to mount a small radio shack scanner antenna on top of a mast that contains a tv antenna.
can anyone advise how far away i should mount the scanner antenna from the tv antenna?
if the scanner antenna is mounted on top of the tv antenna would i have interference from the tv antenna since the scanner cable passes through the tv antenna.
k9rzz
Milwaukee, WI
A few feet of separation would be fine and you shouldn't notice any interaction between the two.
John K9RZZ
