keithmj
Hi all..I was just wondering why you couldn't use PVC pipe for the pole that holds the antenna? As long as you have the guide wires in the correct place to hold it stiff. Right now I'm renting the place where I live and just trying the new antenna out. I had about 12' of one and one-quarter" pvc pipe laying around so decide to try this. I drove 1" pvc about 2' long into the ground leaving half of that sticking out and then I slipped the larger 12' piece over the 1" to hold the bottom of the pole in the ground. At the top I put another 1" piece about a foot long into the 1 1/4" to hold the antenna. I am using 1/8" cord for the guide wires and have been listening to my PRO-96 scanner all day with no problems. This is not a permament setup but it works. I was just wondering because with this setup One could take it camping with them and have a quick setup to listen to the scanner with a better antenna. What is the pitfalls about using pvc pipe for a temp situtation?..Cheers..Keithmj
