Glad someone has a photo of the mount, they are decent mounts but the problem now is since 1972, auto bodies are made of thinner metal and these would take less force to pull out of the body. the newer bodies, some aluminum, easier yet. Take a 3/8 X 1 1/2 flat washer on the inside could reinforce the mount and it would break before pulling out. You still should remove the antenna and put a weather cap on the mount for car washes.It is indeed an Antenna Specialists mount. I installed hundreds of those in the early 70's while working for a local two-way radio shop as a high school student. The hole required was 3/8". The anchor mount snaped into the hole. RG-58 pushed up through. Cable barrel slid over the coax. Once this is done use two open-end wrenches to tightening down the mount.
Shield stripped back and spread out on top of the mount (trim to keep the shield from interfeering with the threads of the cap. The center of the coax push thru the silver cap and the cap tightened onto the mount.
Center of the coax stripped about 1/8" above the mount. Rubber gasket pushed on and then the bared copper conductor pushed thru the hole in the center of the antenna base cap. the center conductor cut 1/4" and bent over into the small groove. Then screw on the loading coil.
As GlobalNorth said the whips were quite long to cover down to 136mhz. We would typically cut off about 9 to 10 inches ( give or take for 155 mhz) and then adjust to minimum SWR using the set screw at the top of the coil.
I still have few laying around. And of course, never saved any documentation.....
I noticed this one doesn't have the elbow at the bottom for the coax, those usually came with the coax installed.
