Hello all,
I would like to use the same antenna on 2 different radios. I will disconnect the feedline from the triplexer and plug it into the antenna switch and use two interconnect cables to connect the switch to the triplexer and the second radio
Everything in black is already in place and working. What's in red i will need to buy. I have 2 questions.
1- If any of you have the Delta-2 coax switch is it a good product ?
2- Is there anything else missing or that i should think of ?
Many thanks
73
De VA2FCS
Many thanks
73
De VA2FCS
