Antenna
N6ML
I forgot to ask you yesterday if you'd noticed (as I "think" I did) that the "purple" antenna was slightly more sensitive to 760 MHz signals than the "blue" antenna? It would seem to make sense that it might if the "blue" antenna was tuned to center more narrowly around 850 MHz, instead of spreading itself between 763 and 870 MHz.
In my experience, there's no discernible difference between them at 770Mhz, observing dBm on the control channel of a site that's not intended to cover my area. The dBm number varies a bit (-108 to -110), so it'd be difficult to observe a subtle difference this way.
kc5igh
Velarde, New Mexico
Maybe the blue antenna is tuned for 850 MHz, but it's clearly labeled as 763 to 870 MHz.
That's certainly true, bob550, but fixed-length antennas have a somewhat-narrow peak resonance range, no matter how they're labeled. I'm guessing that Unication re-designed the "blue" antenna (by shortening its internal element?) to resonate a little more effectively at 850 Mhz than does the "purple" antenna. The "purple" antenna may have been tuned to resonate somewhere between 870 and 763 Mhz (perhaps at around 816 Mhz?).
I'm sure my comment above will be viewed by smarter antenna experts as a gross oversimplification, but I think it's probably pretty close to the mark for the Unication external antennas, which I suspect are helical.
Feel free to fire away, folks!
-Johnnie
bob550
Albany County, NY
I would love to see a Remtronix made for the G5 I don't like adapters
I'll second the Remtronix! I do use an adapter with a RadioShack (Remtronix) BNC antenna and there is a definite improvement to the signal strength even over the blue extra-gain antenna. I'd suppose the length may have something to do with that. But I've found that the blue antenna works well enough in most cases, and has the advantage of being very low-profile.
PapaG
WB4IAR
Hoover, AL 35226
Look at the ExpertPower SMA Female to BNC Female Convert Adaptor for the BaoFeng UV-5R FD-880 on Amazon. I use this adaptor on my G5 and it works well and is low profile.
