I have a Jabra 25e Bluetooth earphones with battery on neck, which are working fine with IC-R30. Unfortunately my Redmi Buds 3 Pro won't pair with Icom. What other TWS buds style earphones are you using and will work with IC-R30?
Airpods pro (1st gen) also works fine with r30. I prefer it because of the Transparency mode which lets outside sound in, so you can hear what's going on around you.
239$?The newly released AirPods Pro 2nd generation work very well with the Icom R30.
239$?
Yep… I believe that‘s what they’re still going for. Original purchase was for music listening, hence was willing (and able) to shell out the money. Very happy with them for their primary purpose. Secondary use is R30 listening. So I’m curious… what’s the point of your question? The OP didn’t mention a price point. Was simply, “what else is compatible”.![]()
My point is that is way too much to spend. Of course you knew that already.
I use the Icom SP40 earphone that can double as an antenna. Runs about 32$.
ICOM SP-40 ICOM Handheld Earphones | DX Engineering
