key2_altfire said:
Hi group,
My wife just ordered a new Mini Cooper S, and I have a spare PRO-2055 (with DIN sleeve) lying around. Offhand I don't know what the dash looks like, and I can't seem to find a good detailed, high-quality pic of the dash online. Anybody know if there are any "natural" mounting spots for a DIN-sized scanner?
Hi,
I found your post while looking for some ideas myself.
I'm assuming you've got the 2007 hardtop (R56, turbo no supercharged headlights separate from the bonnet) If that's the case then you are in luck as you'll have a second "secret" glove box, a dash panel which you can press and open, it appears slightly larger than DIN size.
If you ordered a Cabriolet then you've got the same model as me and there isn't really much as the gap between the downtubes is about 1 size too small for a DIN unit.
I'm trying to hook up a B996T and the best solution I seem to have is a thru-glass antenna going to the B996T in the glove box then I've got the remote head, I'll trim the downtubes in the spring (I'm up north and it was 4F this morning, I'm not going out to the car to mess around in that) I'm setting up a separate switched power fuse box in the glovebox, and it should basically look OEM when I'm done.
I'm a regular at northamericanmotoring.com and know there are a few HAMs and scanners over there, and I've seem some really nice HAM installs. It might be worth your time signup searching and PMing some folks for how they did they're installs and what hurdles they faced. Plus it's a great community and plenty of MINI info should you want to meet other owners or have questions not covered in the owners manual.
Motor On!
-Drew
