Anytone Anytone 778uv II
bortweb
Hi,
I'm my friend is using an at-778uv radio but he can't find the way to keep the keypad lock. He would like it lock most of the time that way is childrens or passenger can not change channel and or setting on the radio by bumping on it. We were able to lock it by pushing the channel button and holding for 3 seconds but when he turn off is car then on the radio is still unlocked. Can you guys suggest a way to lock it all the time?
VK5AC
Adelaide, South Australia
Hi. Press and hold rotary dial on radio till lock shows on display then keypad on mic goes dark to show no control, as likely you know.
I can only add in the software programming there is an option in mode for lock. I suspect this might be for power up in the locked state. Worth a try.
FKimble
Newnan, GA
Just re-lock it when ever the car is started back up. Or put the mike where the kids can't play with it.
Frank
