For your power supply, use terminals that attach to the posts, not the banana plugs. The banana plugs are too easy to have a poor connection, or end up swapped. I see it has a detachable power cord, so having dedicated cables might make life easier.
Is the pic of the power supply you sent actually the one you have? If so, and if you are in the U.S. - that is NOT a power supply designed for use in the U.S. The AC power socket is marked "INPUT 220V 50Hz". A supply intended for use in the U.S. would be marked "INPUT 120V 60Hz" or something very close to that.@popnokick SWR came in today, but it appears it has N type connections instead of 239 like advertised. I cannot find one that shows a 239 connector- they all say they are So239- if so i need connectors for the radio and antenna.
1. Do all these SWR meters like this come with N type?
2. What connector do i need to the radio coming in
3. what connector do i need for antenna?
I think i need https://www.amazon.com/Antenna-coaxial-adapter-Adapter-connector/dp/B076GXJ63N/ref=sr_1_1_sspa?crid=30J1BA1OJ4802&keywords=uhf+female+to+n+type+male&qid=1649712846&sprefix=uhf+female+to+n+type+male,aps,84&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExTkxKMExYTzZPVk5RJmVuY3J5cHRlZElkPUEwNjA5MDI2SkxLOVg4M0ZEWjBUJmVuY3J5cHRlZEFkSWQ9QTA2MTQyODgySFBXTk81WEQ0U0hBJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
can anyone confirm?
Also, trying to plug in the back of the power supply from the radio with banana clips (the ones below). They do not make a full connection in the back of the radio- so instead of wrapping the wire around the post, there is a hole in it that it will accept some kind of plug- not sure which one.
the power supply
thanks
Here are the complete specs and instructions for each of the Ed Fong antennas. PLEASE READ THIS -So technically i could drape it outside my window? It's hard to see on the website what connections come with it (it says many) and i am assuming it appears to come with paracord attached to it.
is there a pro/con on each model? I could take the roll up version and put it in PVC myself? If so, would i need to drill a hole through the end cap and make my own connection? In the image the roll up version appears to have connectors at both ends?
thanks, just wondering if i should get the roll up or wait for the pvc version to come back in. Same antenna and i assume the roll up one is meant to be used hanging between trees outside. If the roll up version is is just paracord attached to it, trying to figure out if cutting it would ruin the antenna.
As AK9R already stated, the connectors on the power supply take banana plugs. (Which are what you had pictures of, in an earlier post.)what are the names of that type of connector in the back of the power supply? They unscrew and allow me to put a ring connector on it, but it also has a hole in the center and i cant seem to find the name of that conection type and if it allows a plug into it. Just wanted to make everything look "prettier" so i can get rid of the rats nest of cable going from the radio to the supply.
thx
In my experience the ring terminals supplied with the Powerpole / PowerWerx cables fit on the Astron and other popular power supplies. This web page (on the website I sent you in my prior message... did you look at it?) has all you need... and then some -
https://powerwerx.com/adapter-extension-cables
