AOR
Patrol1949
uk
So I am thinking about getting a AR5700D if I was to get one off
These sets what can expect to hear in the 2 GHz and 2 GHz range.
I already have the DV1 .
Zentral Europa
I also observed the range up to 2 GHz with the ICOM IC-r 8500, but unfortunately I didn't receive anything useful.
I think the normal listener can no longer really hear anything after the 23cm amateur radio band.
Patrol1949
uk
I think I will give it a miss for now .
Thanks all for your help.
Patrol1949
uk
Yes we are the other side of the pond but two weeks ago
We were your side in Miami and I took my scanner
Grate fun.
Patrol1949
uk
A little help needed on P25 settings for the uk that is
Step and Band width. At the moment I am using 12.5 Step
And 15K for Band width .
Thanks.
G7RUX
As is always the case, the antenna system will be probably the most important part of your setup. once you get above UHF the PSDs in use are lower so a decent antenna with some gain will be important. If there are particular systems you want to listen to then go for dedicated antennas for the relevant frequencies and the best coaxial cable you can manage, possibly with LNA and filters.
Alan1268
Hi Patrol1949, How are you finding your new toy? Looking at one of these myself and wondering if it is much better on vhf/uhf airband than the AR5000, if you've had chance to try it in that frequency range?
Thanks.
Patrol1949
uk
Hi Alan all I can say brilliant DMR is exultant and it is very clear
The receiver really picks the week signals out .But dose take a lot
Of getting your head around it but it is fun learning all its functions.
I am over the moon with it.
Patrol1949
uk
Has anyone managed to get this running the AR-IQ-III interface
Try as I may all I keep in device manager Device not found .
SigIntel8600
Communications Receiver Nut
Pine Barrens
When you get the device not found, leave your cable plugged in and turn off the 5700 then turn it on again.
Patrol1949
uk
Yes I tried that still no joy the PC will even load the drivers of the mem stick.
I am now going to reinstall windows 10 to see if that helps.
