Sipho
I've had this BCD396T about 3 weeks and have been having problems when receiving any P25 systems. short transmissions are not clear. After a few seconds on a longer transmission the audio is sometimes much better. Some voices have higher voice peaks and they distort pretty bad. I've tried setting the threshold to optimize the decode threshold and it helps but still bad. I noticed on the signal strength indicator that it is not steady. Even if I go to hold. It seems to be like scanning. I can get 5 bars but then they drop to 1 or 2. On conventional sysems it is steady. I've tried with AGC both on and off and no change. Close call is switched off. Seems like women voices are harder to copy. I also tried Auto, manual and default on the threshold and also Auto, FM, and NFM with the modulation. They have little or no effect.
Question.. Is this all the better it is suppose to work or do I have a problem with a bad scanner?
Question.. Should signal strength be steady when receiving in P25 mode?
I called Uniden support and they offer little or no help? If I need to send it in then I will but do not want to be without it for 3 weeks and have it come back saying nothing was wrong and it being in the same condition.
I guess what I'm asking is does the P25 system sound as good as the other systems?
At times I can not understand them.
