APX 4000 / KVL 3000
n9zip
Michigan City, Indiana
I have two KVL 3000s and both are the same. I want to use the KVL on the APX 4000.
When I connect the radio, the radio displays "KEYLOADING"
When I select load on the KVL, the load icon appears, then a error message.
I do not have mode select on the KVL, so I don't have ASTRO 25 on the KVL.
Any Thoughts???
Ken
Motorola Certified APX Programmer
n9zip
Are you sure your radio is programmed for hardware and not software ? What algorithm are you trying to load ? and does the MACE have that in the radio ?
Yes i'm in hardware, the radio sees the kvl.... ALGO is dvp-xl dont see MACE. I can't switch to any modes on the KVL
n9zip
It's like learning to ride a bike with training wheels.... This what the KVL is telling me after trying to load a key. KEY LOAD FAILED NO SECURITY TEST ACK RCV FROM RADIO.... I'm betting the firmware on the KVL was never updated.
NVAGVUP
Here is what I have. APX4000 can only support one non ADP encryption type within build. Although the sales pages do not state APX4000 supports DES/OFB, it does. You need to work with sales rep. (But it will be at the expense of not having AES in radio). (No DVP or DVP-XL listed)
RE: DVP or DVP XL. I could only find this sales option (DVP XL) on higher tier (EX APX6000/8000) offerings. These are analog encryption types and not supported on any current infrastructure. Good luck. You will need it.
